It is currently Sun Jul 20, 2025 6:56 pm
PostPosted: Sat Aug 13, 2011 8:37 am
Hi! As the title says, can I use rabbit skin glue or bone glue (or mixture of both) for a neck joint? Or else, which of the two would be better? I know that HHG is preffered, but all I could find here were those two, and I bought them from a painters' supply shop. Thanks!
PostPosted: Sat Aug 13, 2011 12:11 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Both are HHG...
We just usually find them pre-mixed.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sat Aug 13, 2011 4:06 pm
First name: Alex
Last Name: Takacs
State: Illinois
Personally, I use titebond 1 on fretboards (to allow for removal in the future) and titebond 3 on everything else. Titebond 3 might be a little overkill but I like to make sure that I wont have any glue-joints breaking in the decades ahead. I poked areound a bit and I found this stuff on stewmac if your interested in hide glues http://www.stewmac.com/shop/Glues,_adhe ... _Glue.html
PostPosted: Sat Aug 13, 2011 9:12 pm
Last Name: Thiessen
City: Lexington Park
Absolutely do not use the Franklin liquid hide glue for a guitar. Absolutely horrible stuff, does not hold under pressure. I built two guitars with this stuff and had to rebuild them both because the glue did not hold. I did a little bit of research and found that no body uses it. Normal hide glue is fine, but not the stuff from the link to Stewmac. I can't believe they are selling that stuff.
John Thiessen
http://www.iszacguitars.com
PostPosted: Sat Aug 13, 2011 10:13 pm
First name: Alex
Last Name: Takacs
State: Illinois
Thanks for your comment/correction [:Y:] I've never used the stuff so i didnt really know about the quality. You may have saved "Als" and anybody else who read this thread a WHOLE lot of trouble!
PostPosted: Mon Aug 15, 2011 9:41 pm
I used the franklin hide glue on my set neck telecaster and have not had a problem with it. I have read however you need to get a bottle that was made less than 9 months ago.
Users browsing this forum: Bing [Bot] and 1 guest
